gduesbur Posted May 18, 2016 Report Share Posted May 18, 2016 Hot Spring ACE System - Failed Cells Has any one tested "The Deuce" - Direct replacement for Hot Spring ACE System cell at 1/3 of the price? http://www.saltwaterhottubconversion.com/saltwater-products/chlorine-generator-parts/replacement-cells/hot-springs-chlorine-replacement-cell.html Gord Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 3, 2016 Report Share Posted June 3, 2016 I've never heard of it. Do you know the saltevel required for el deuce? As long as it's in the same range as the ACE cell (~1750ppm) looks like a possible $$ saver. You'll lose a few benefits of ACE (the ozone and other oxidizing gas) but you'll save a few hundred bucks. Quote Link to comment Share on other sites More sharing options...
HVAC-NW Posted September 23, 2016 Report Share Posted September 23, 2016 The Deuce replacement also calls for a significant increase in calcium hardness from the Ace's recommended 50 to between 200 to 400 ppm with the Deuce. If this is not followed, the warranty is voided. Quote Link to comment Share on other sites More sharing options...
gduesbur Posted August 23, 2018 Author Report Share Posted August 23, 2018 http://www.saltwaterhottubconversion.com/saltwater-products/chlorine-generator-parts/replacement-cells/hot-springs-chlorine-replacement-cell.html Quote Link to comment Share on other sites More sharing options...
