Alyssa Posted January 11, 2016 Report Share Posted January 11, 2016 How can I clean my pool using simple methods. I search some stuff, found nothing but some difficult methods. some easy methods help me in sense of my pool cleaning issue. Quote Link to comment Share on other sites More sharing options...
ronnyaderson Posted February 8, 2016 Report Share Posted February 8, 2016 If the pool water is dirty you do not even have to do much just grab the nearest net and skim out the leaves and the debris floating around in the water. If the water remains dirty clean your cartridge make sure it is not get damaged. If it is damage replace ASAP Quote Link to comment Share on other sites More sharing options...
Joshua Moore Posted June 3, 2016 Report Share Posted June 3, 2016 If the pool water is dirty you do not even have to do much just grab the nearest net and skim out the leaves and the debris floating around in the water. If the water remains dirty clean your cartridge make sure it is not get damaged. If it is damage replace ASAP I totally agree with your comment. This is quite fine enough. Quote Link to comment Share on other sites More sharing options...
CarolCPalmer Posted August 17, 2016 Report Share Posted August 17, 2016 First skim off leaves and debris, using abrush remov edirt on the sides and bottom of the pool. Accumulate the sediment towards the main drain which can be easily vacuumed. Remember to clean your skimmer. Check for the water circulation (skimmer, pump, pump stariner, drains and filter) and check for filter (sand, cartridge, grid DE), screen out debris and particlesfrom your pool water. test your pool water regulkarly and add chemicals if necessary. Shock treatment would ensure cleansing of algae. Refer this article for few easy tips for cleaning pool http://www.soldapools.com/blog/cleaning-pool/5-easy-ways-to-keep-your-pool-clean/ Quote Link to comment Share on other sites More sharing options...
AdamHarper Posted November 26, 2016 Report Share Posted November 26, 2016 Nice ideas! Quote Link to comment Share on other sites More sharing options...
noman Posted January 5, 2017 Report Share Posted January 5, 2017 Thanks for sharing the tips carol... Quote Link to comment Share on other sites More sharing options...
ScottAlexander Posted January 12, 2017 Report Share Posted January 12, 2017 You can use a pool vacuum to clean the floors of a swimming pool much the same way you would vacuum a carpet. Some automatic cleaners do not require you to vacuum yourself. Quote Link to comment Share on other sites More sharing options...
savanah Posted January 17, 2017 Report Share Posted January 17, 2017 Scrubbing, brushing, and shocking could be the easiest way to clean your pool. Quote Link to comment Share on other sites More sharing options...
