Prodigy Hotspring Spa - Found Rubber Washer
elav
Hello, I was doing some much needed maintenance (clean filters, replace Silver Ion cartridge, shock) when I noticed a rubber washer in the filter compartment. It is a bit larger than a quarter in diameter. I always top off water levels by placing a hose in this compartment, so I'm assuming this rubber washer was stuck on the end of the hose and fell off when filling, but I wanted to check with the community on this. I'm not sure how to attach an image but it is twice as thick as a quarter and seems like it would fit nicely inside a sprayer that typically attaches to a garden hose. Thanks for any feedback!
-Alan
You very likely found the garden hose gasket that was on the end of your garden hose. When the high pressure nozzle was taken off, the gasket stayed stuck to the hose, then fell off in your filter compartment. The spa has no gaskets that size, except the drain gaskets on the drain caps, which are garden hose gaskets :)
