robquick Posted December 13, 2015 Report Share Posted December 13, 2015 Evening, Occasionally my Chlorine levels are 3-5ppm when I come to use the tub, in hindsight I'm guessing this is really too high for bathing. I thought one solution would be to use Chlorine reducer prior to bathing if the Chlorine levels were high. A couple of questions - How quickly does 'reducer' take to work ? If you ended up using too much reducer would you then need to use more Chlorine than usual after bathing...........or does it not work in that way ? Does Chlorine reducer have any other effect on the water other than just reducing Chlorine levels ? Thanks. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted December 13, 2015 Report Share Posted December 13, 2015 3-5ppm is fine to use. Quote Link to comment Share on other sites More sharing options...
chem geek Posted December 14, 2015 Report Share Posted December 14, 2015 You should just be able to add a little less chlorine after your soak so that you start with 1-2 ppm FC before your next soak. That would be the easiest thing to do. If you really want to lower the chlorine level, then you can use 3% hydrogen peroxide for that where you would use the same volume of it as the volume of 6% bleach that has the FC amount you want to lower. You can use PoolMath to calculate that volume. As Dr. Spa says, there's nothing wrong with 3-5 ppm FC for a soak. Some people prefer to soak in a lower level of chlorine mostly to avoid as much chlorine/chloramine smell, but it's not unsafe. Quote Link to comment Share on other sites More sharing options...
