obrienjm Posted May 13, 2015 Report Share Posted May 13, 2015 Hi all.... I'm new to this forum and I have a service question that the customer service manager at Artesian couldn't solve; also a spa repairman on site at my house couldn't solve. So I am hoping the collective wisdom & experience from this site might be able to uncover my mystery. I have had this issue for over a year -- I know, a whole year without my spa!! I have a 2006 Artesian Piper Glen (Platinum Series). In the spring of 2014 my spa stopped working. After some initial troubleshooting, I was instructed to purchase a new spa pack. So, I installed a new in.xm2 spa pack. When that didn't solve my issue, I was instructed that it could be my heater could be faulty. So I replaced that as well. CURRENT ISSUE: When I turn on the power, I am getting the blinking “SP-IN” error code but I can’t change anything. The “select” key is unresponsive, even after holding down the select key for 10-15 seconds. So I am unable to set the LL code to 28 (told to me by Gecko dealer through Artesian service dept). I have checked and rechecked the connections -- they are tight, no corrosion, etc all the way back to the main breaker. I have checked and rechecked the voltage. Here’s what I did and the results: Checked the voltage at the spa pack on the tops of the terminals (big bolts):o Hot#1 to white= 119.7vo Hot#2 to white= 120.0vo Hot#1 to Hot#2= 239.9vo White to ground=0.029vThere is still no response when trying to press the “select” key for 2 sec, 5 sec, 30 sec. BTW, I have tried re-installing the old equipment as well. The Model & Serial numbers for the equipment are as follows:SPA:Model: Pipe GlenSerial #: 71505Date: June 5, 2006Control Panel: ink.600NEW EQUIPMENT (currently installed):SPA PACK (in.xm2):Model: IN.XM1 (prod ID 0601-221104)Serial #: 141000748GIN.THERM:Model:IN.THERM-H4.0 (prod ID 0603-409001)Serial #: 132820202GIn case you need to know...ORIGINAL EQUIPMENT (previously installed):SPA PACK (in.xm):Model: IN.XM1 (prod ID 0601-221010)Serial #: 060531571IN.THERM:Model:IN.THERM-H4.0 (prod ID 0603-416001)Serial #: 060411581 Does this make any sense to anyone?? Thanks for taking the "challenge" /Joe Quote Link to comment Share on other sites More sharing options...
Sinister Posted June 1, 2015 Report Share Posted June 1, 2015 I am having the exact same issue Have u had any luck ? Quote Link to comment Share on other sites More sharing options...
Sinister Posted June 1, 2015 Report Share Posted June 1, 2015 I'm getting 124v from each. Giving me 248v. I am using a different cord to power my tub do I thought that might be the issue. I've got a new heater, pump and spa pack. I'm getting ready to give this thing away soon. So frustrating!!! Please let me no if u figure anything out and I will do the same Quote Link to comment Share on other sites More sharing options...
Gcxl7000 Posted September 24, 2015 Report Share Posted September 24, 2015 Just had a break through with the same issue. Turn your spa off at the outside breaker, then unplug all of the big main plugs, then turn your unit back on. Mine had no error codes at all. Lmk if it works. Quote Link to comment Share on other sites More sharing options...
JIJOE Posted September 1, 2020 Report Share Posted September 1, 2020 On 9/24/2015 at 4:15 PM, Gcxl7000 said: Just had a break through with the same issue. Turn your spa off at the outside breaker, then unplug all of the big main plugs, then turn your unit back on. Mine had no error codes at all. Lmk if it works. Do you plug them all back in before you turn the breaker back on? Sorry newbie on board....Thanks for the help Quote Link to comment Share on other sites More sharing options...
