HardLuck Posted March 23, 2015 Report Share Posted March 23, 2015 I just purchased an older Cal Spa and found that the filter bypass valve is broken, thus I am getting very poor filtration as the water is just bypassing the filter. I was told that it is a good idea to just replace the whole housing, rather than try to fix. Is this true? Also it is a top load suction filter system and was wondering if it is better to just switch to a pressure system and install a canister filter in the cabinet. Thanks Quote Link to comment Share on other sites More sharing options...
sieb21 Posted February 24, 2019 Report Share Posted February 24, 2019 Im having the exact same problem? What did you finally do to fix it? Do you replace the whole filter unit? Thanks Quote Link to comment Share on other sites More sharing options...
Cusser Posted February 24, 2019 Report Share Posted February 24, 2019 I have a 1988 CalSpa, and kept having trouble with leaks at the filter assembly and cracking of its rather expensive giant plastic nut. Worse was that there was essentially no room to lift off the filter cover to get it out of the cabinet so the filter cartridge could be cleaned. So a couple of years ago I decided to buy an entire new filter assembly of a different style, and I routed the water flow OUTSIDE of the cabinet to that filter, and then back into the spa. I added shut-off valves on both sides of that filter. This is all on the hidden side of the spa, enabled me to keep having the spa. Can you post good clear pictures here of your situation, maybe draw red arrows pointing to your problems there, I'd like to take a look, maybe there's something you could do. Quote Link to comment Share on other sites More sharing options...
Jc21 Posted November 28, 2020 Report Share Posted November 28, 2020 I found this piece broken on the side that holds the flapper and the flapper no longer being held by the holder. Can I just buy these parts and put them in the spa? Thank you. Quote Link to comment Share on other sites More sharing options...
