JLM Posted October 16, 2014 Report Share Posted October 16, 2014 Jandy Pool Heater LX400N-L Manufactured 2003 will light sometimes and when it does, it will not re-light when the water cools off. I get an AGS error code. Before this happened it was blowing a 2A fuse. The tech said it was time for a new heater. Any suggestions before spending $3000+? Quote Link to comment Share on other sites More sharing options...
MikeThePoolman Posted October 23, 2014 Report Share Posted October 23, 2014 I love Jandy but that heater has had MANY issues. Cut your losses and buy a new heater. I am very good at heater repair and I've been down this road too many times- repair, another repair, another repair, $900 later and you've got an 11 year old heater that's still temperamental. Go Pentair or Sta-Rite and you'll be fine. Mike Quote Link to comment Share on other sites More sharing options...
drandolph Posted October 26, 2014 Report Share Posted October 26, 2014 I'm a warranty station for jandy in sacramento area i have used there products for many years i have to agree w/ mike that heater model has had many issues i am a big fan of hayward & sta-rite heaters but I'm in love with new new heater jandy just came out with the new JXI is a really cool unit and its way lighter & compact a guy can carry it buy him self no problem Quote Link to comment Share on other sites More sharing options...
JLM Posted October 31, 2014 Author Report Share Posted October 31, 2014 Thanks for your feedback. Quote Link to comment Share on other sites More sharing options...
stevenz1g Posted December 13, 2014 Report Share Posted December 13, 2014 Although an AGS sensor is a cheap fix, it's weird that the hi-limit isn't also popping, as they're usually within a couple degrees within each other. Simply put, the AGS sensor simply tells the gas valve to shut because water temperature leaving header is too high... which could mean a slew of things (flow, heat exchanger, bad sensor, bad pc board, bypass inside header bad?) If you're mechanically inclined in the least sense, put a multimeter on the sensor and see if it's always bad, opens early, or is in fact opening as it should be. Compare with your hi limit sensor. If you've had a good history with your tech, and judging by these other commentors, it may be time for that new heater. Quote Link to comment Share on other sites More sharing options...
