rgbraun1 Posted September 6, 2014 Report Share Posted September 6, 2014 My intellichlor ic40 (I think) is not lit up, has no power. There is NOT a fuse next to the plug at the bottom of the control panel. At the top of the panel, behind the control buttons, is a black 10 amp white breaker button. Need some help. Thanks, Gabe Quote Link to comment Share on other sites More sharing options...
rgbraun1 Posted September 7, 2014 Author Report Share Posted September 7, 2014 Extra info: the power LED green indicator on the circuit board for the intellichlor is on. The white 10 amp is a load center resettable IOA breaker. Quote Link to comment Share on other sites More sharing options...
stevenz1g Posted September 17, 2014 Report Share Posted September 17, 2014 If your power LED green is indicating on, then "most likely" you're receiving the proper voltage necessary as wired and as being transformed(either 120v or 240v -> 24v). At either rate, I'd check your wiring for the incoming power. If you have 120v, make sure the hot is tied with the "yellow and black" and the neutral tied with "blue or violet" & "white". If 240v, it will be hot with "yellow", the other hot "white" and the extra "blue/violet" and "black" tied together. After ensuring proper voltage and making sure fuse(s) are working properly, test the outbound side of the transformer by placing your voltage tester leads where you connect the chlorine generator (without actually plugging in. Imagine you looking up, from the bottom, at the unit. You'll see four little holes. Place the leads in two opposing holes and check for voltage. I can't remember which holes they are, but two of them will be sending 24v DIRECT CURRENT if transformer is working properly and fuse is working great. If you don't get 24v, then your power center is bad and needs replacing. If you are getting 24v, then you need to replace cell and/or send in for warranty. Quote Link to comment Share on other sites More sharing options...
Arnaldo Posted March 8, 2020 Report Share Posted March 8, 2020 Where to buy intelichlor controller. Thanks Arny Quote Link to comment Share on other sites More sharing options...
