michelb Posted September 2, 2014 Report Share Posted September 2, 2014 Hi, our spa (about 10 year old) with a Spa Builders S class board isn't really heating. We're getting the 3 flashing dots so I thought I had to replace the pressure switch. The catch though is that when it first powers on, it's fine, it's only after it completes a heat cycle that I get the 3 flashing dots (i.e. disconnect spa when the water isn't that hot (i.e. below 100), reconnect spa and the heater works fine but as soon as it hits 100 and it stops heating, then you get the 3 flashing dots. Even once the water temp drops below where it should start heating again, it doesn't. (you also get the same behavior by making the set point up / down). One thing I did notice is that if I simply disconnect one of the leads on the pressure switch and then wait 1 second before reconnecting, the 3 dots will go away and it will work fine until the heater turns off again. I can also reproduce this if I remove the adjustment valve screw and simply push and hold the "plunger" on the pressure switch for 1 second. In case it's not clear, I thought it was the pressure switch so replaced that but that hasn't solved my problem. Any suggestions or is this a sign that something is wrong with the spa pack and I need to replace it. Any suggestions are greatly appreciated. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
eaquacare Posted September 2, 2014 Report Share Posted September 2, 2014 Since you mentioned its 10 yr old, it could very well be a faulty heater element, due to rusting/other deposits/water chemistry issues. i believe replacing the heater element is cheaper than replacing the unit. However not sure if they sell universal heater element for this particular Spa. I assume you have checked for loose connection and also for faulty relay and flow switch. Good luck. Quote Link to comment Share on other sites More sharing options...
michelb Posted September 3, 2014 Author Report Share Posted September 3, 2014 Thanks for the info. The element is fine (forgot to mention that this is the first thing I replaced thinking it was dead). It could be a relay but as mentioned, if I just pull one of the contacts on the pressure switch and reconnect it after a second, it works fine but you have to do this to "reset" it every time. Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted September 3, 2014 Report Share Posted September 3, 2014 Can you provide more information on the flashing LEDs, they typically indicate the condition or fault. How many times is the "heat indicator" flashing? Quote Link to comment Share on other sites More sharing options...
spokanespas Posted September 5, 2014 Report Share Posted September 5, 2014 While the three flashing dots are present on display, check the circuit board bottom right corner for a red LED on solid. If LED present then high limit failure and likely sticking heater relay is the problem. This is a repairable failure. If no LED on pc board then pressure switch is sticking on after pump shuts off = bad pressure switch. Brandon@spokanespas.com Quote Link to comment Share on other sites More sharing options...
michelb Posted September 5, 2014 Author Report Share Posted September 5, 2014 Thanks for the quick response. I didn't see any solid red LED but I'll have another look. It does sound like it's a bad pressure switch but I just replaced it with a new one so I'm wondering if it's something on the board itself. I guess I'll have to do more investigation. Thanks. Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted September 9, 2014 Report Share Posted September 9, 2014 My money is on Brandon being correct, he has repaired boards for my customers for 3 years now, and he has never had to fix one twice. Quote Link to comment Share on other sites More sharing options...
RyanDolby Posted June 20, 2019 Report Share Posted June 20, 2019 Hello, i am having the same issue and do have a solid red led light. Any suggestions on how to fix the stuck relay problem? Thanks, ryan Quote Link to comment Share on other sites More sharing options...
redneckrick Posted August 31, 2020 Report Share Posted August 31, 2020 i kinda have the same issue and noticed the cr12 light is on...is it my heater or pressure switch Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted September 2, 2020 Report Share Posted September 2, 2020 try resetting power and see if the red Led indicator goes out, this is a HL condition. Quote Link to comment Share on other sites More sharing options...
Hot tub scott Posted February 25, 2021 Report Share Posted February 25, 2021 I am having the same issue with a spa with m class pack and hockey stick heater. We have replaced The pump The heater The flow switch Temp probe High limit probe Top side And BOARD itself Run the tub with the filters out. Same problem gets to temp and drops down won't heat again until reset. Someone please help Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted February 25, 2021 Report Share Posted February 25, 2021 Sounds like you have replaced everything already. Test the flow switch operation. Verify wiring and any board jumper settings, especially relating to pump operation. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 25, 2021 Report Share Posted February 25, 2021 @Hot tub scott Please start your own thread and post pics of the circuit board and the schematic on the inside cover. Quote Link to comment Share on other sites More sharing options...
