dd1153 Posted August 27, 2014 Report Share Posted August 27, 2014 I recently purchased a Dynasty Victory II spa from a friend and had it (professionally) moved to my house. I hired a company to build me a deck and run electrical lines, as well as hook up the tub. We got to use the tub last night and it worked flawlessly.. Pump 1 & 2 fired, heater got super hot, jets, bubbles, the whole package. Today I wanted to let my daughter get in, so I fired pump 1 & 2 up today around 4pm. At approx 5:24pm my hot tub shut off, and started flashing the code Hr - - - 5:24 see youtube video here: and it would repeat. The only thing that has changed (electrically) is I switched on a 110v breaker to a GFCI that the company ran for me thats in the spa breaker box. I googled the error and found the user manual for the 2011 Victory II and it states that this is a hardware issue. I reset the breaker, turned off the 110v breaker, emptied the hot tub, refilled the tub, turned on the 220v breaker and I'm still getting the error. I called Dynasty and they said unplug pump 1/2 and ozone / blower from the main panel.. start tub up and see if Hr appears. I did this.. and it does. so my question is, could this happen from overheating? Running both pumps at 4pm - when its about 100f outside? Or do I need to have a service call .... on day #2 of ownership? Thank you Quote Link to comment Share on other sites More sharing options...
Roger Posted September 2, 2014 Report Share Posted September 2, 2014 Sorry it took so long to get to you. I don't have the control box specs but I would check resistance through the heater first and suspect that, with that error. Could be the hardware they are talking about. 3-4 years on a heater can happen depending on a lot of factors. Does it pump with or without the heater hooked up? Quote Link to comment Share on other sites More sharing options...
