C4wilson Posted August 25, 2014 Report Share Posted August 25, 2014 Trying to troubleshoot why i get the "RH NF" error (no flow or low flow to heater). Looking for any advice. I've tried cleaning the filters. No change, removed the filters temporarily and still go the error. Opened the PVC out of the heater and let out some air (I actually heard a bit come out) and then water came out. But still get the error. Any other suggestions? Thanks. Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted August 26, 2014 Report Share Posted August 26, 2014 Type of spa? Two speed or single speed cuirc pump? Throw us a bone here. Quote Link to comment Share on other sites More sharing options...
C4wilson Posted August 26, 2014 Author Report Share Posted August 26, 2014 Type of spa? Two speed or single speed cuirc pump? Throw us a bone here. Thanks for the reply! It is a artesian quail ridge platinum from 2007. I am not positive but think single speed for the pump. I really appreciate the help! Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted August 27, 2014 Report Share Posted August 27, 2014 They recommend filling the spa thru the filter intake without the filters in during start-up, you may have a air lock, if you are getting visible flow, this is not the issue, you may have a corroded pressure switch, disconnect the switch and run an ohm test on it. Page 27 of your owner's manual covers the initial things you want to check, there is a PDF of it here ~~~> http://www.spaparts123.net/files/2007_Platinum_OwnersManual.pdf Quote Link to comment Share on other sites More sharing options...
C4wilson Posted August 31, 2014 Author Report Share Posted August 31, 2014 Thanks spa guru. I have been filling from the intake so I'll try the ohm test. I didn't see reference to this in the manual, do you just mean use a dmm on the heaters plug and test for resistance? Thanks! Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted September 2, 2014 Report Share Posted September 2, 2014 Disconnect the wires from the switch, then with the tub off, you should get infinite ohms, with the pump running you should get zero ohms. Quote Link to comment Share on other sites More sharing options...
C4wilson Posted September 3, 2014 Author Report Share Posted September 3, 2014 Thanks again for the response spa guru. Apparently this model does not have switches. According to http://www.artesianspas.com/spa/platinumelite/quailridge.html it says "Switchless Motors The use of switchless motors insures the longest pump life of any spa on the market. Virtually failure-proof switches are used in the Platinum Elite Spas, instead of pressure switches" Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted September 5, 2014 Report Share Posted September 5, 2014 Switchless motors does not mean switchless heaters. often the flow switch is a couple feet away from the equipment, and if you have a FL error, it is coming from either a pressure switch or a flow switch. The pressure switch looks like this; Or this; Your flow switch probably loos like this; Quote Link to comment Share on other sites More sharing options...
