Tubber McGee Posted June 2, 2014 Report Share Posted June 2, 2014 Hello, I have a 2010 Hotspring Vanguard. I recently had to get a replacement Cell for my Salt/Ace System. Because we do not use the tub in the hot summer months much and the fact that the Cell that produces the chlorine only has so much life, I was thinking of replacing the Cell in the fall, prior to heavy use in order to get more life out of the cell. What this means - For the next 3 summer months we would have a working tub with a failed Cell (which means no chlorine is being produced). I do shock the tub ever so often. Question - would this hurt my tub at all? pipes - motors - pumps??? I am OK to wait or should I just go ahead a replace now? Thanks Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 2, 2014 Report Share Posted June 2, 2014 Won't hurt it at all. ACE is an option, simply take care of the tub as though it doesn't have ACE Quote Link to comment Share on other sites More sharing options...
Tubber McGee Posted June 2, 2014 Author Report Share Posted June 2, 2014 Thanks for the reply - so am I fine to NOT add chemicals and just shock once in a while due to no use or are you saying I should be balancing my water by purchasing other chemicals? which I would rather not do!! Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 2, 2014 Report Share Posted June 2, 2014 I'm not really following. Ace isn't a replacement for PH, Alkalinity, etc, it's simply a mechanism that constantly produces chlorine out of salt. Think of it as a little guy who's always adding a pre-determined amount of chlorine that you have programmed via your ACE menu. You still need to balance your PH and Alkalinity with, or without ACE. Now, you'll need to add a small amount of chlorine, or non-chlorine shock, since the ACE system is not working. Read your owners manual, or, just look on the inside of your filter lid for the cliffnotes version. Quote Link to comment Share on other sites More sharing options...
Tubber McGee Posted June 3, 2014 Author Report Share Posted June 3, 2014 Thanks again - I was thinking of putting NO chemicals in the tub and not worrying about balancing PH and Alkalinity since we will not be using the tub - My concern was if this could cause any damage to the tub or part inside? I guess I could just drain the tub for the summer and replace the cell in the fall when we use the tub on a regular basis!!! Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 3, 2014 Report Share Posted June 3, 2014 Imbalanced PH and Alkalinity will can be very harmful. Ensure they're balanced, then once a week, drop in a teaspoon of sodium dichlor granular chlorine- no need to shock if no one is using the spa. The PH and Alkalinity will remain balanced once you get them balanced. Quote Link to comment Share on other sites More sharing options...
Loopcity Posted June 15, 2014 Report Share Posted June 15, 2014 If you aren't going to use it, just drain it. Wouldn't be a bad idea to do a system flush while you are at it. During times of no use, people tend to not take care of it and that's when bad things happen. Quote Link to comment Share on other sites More sharing options...
chem geek Posted June 15, 2014 Report Share Posted June 15, 2014 We now recommend Ahh-Some® rather than Spa System Flush or Swirl Away because it seems to do a more thorough cleaning. Quote Link to comment Share on other sites More sharing options...
