Sundance Maxxuss 880 - No Heat + No Circulation
Hello,
My tub flashes flo. It will not heat or circulate. I shut off the power for several hours to reset.I changed the filter. All three pumps work and I did the air bleed trick from the top massage valves opposite of the filter side. I also tapped on the flo valve and it seems to circulate ok when the pumps are running.
Should the bleed trick be done several times?
Water will not flow from within the system even with the waterfall valve open.
Emergency heat will not come on even though the water temp is 30 degrees below the set temp.
Also when I tap the button for pumps 2 and 3 when every pump and bubble maker is on all the pumps shut off.
I am thinking circulating pump? or perhaps heater too?
Are there any large fuses to check?
Any suggestions will help. Thank you in advance.
Sara
