Eric859 Posted February 10, 2014 Report Share Posted February 10, 2014 When I turn on the hot tub, this is what happens: 1) Jet 2 of 2 starts immediately and stays running 2) The circ pump turns on and off again for about 10 minutes before completely turning off 3) The display shows 3 blinking dots, but the temp is accurate 4) The tub light comes on and cannot be turned off 5) Jet 1 cannot be turned on. Any ideas? Quote Link to comment Share on other sites More sharing options...
Eric859 Posted February 10, 2014 Author Report Share Posted February 10, 2014 OK, I found the issue with the 3 blinking lights. The flow switch is faulty. LA Spas showed me that if I turn on the tub with the flow switch disconnected from the main board and then reconnect it, the issue with the circ pump goes away. It did. The problem I have now is that Pump 2 turns on as soon as the tub is powered on and can't be turned off and pump 1 is non responsive. The control panel I swapped out seems to be working fine and shows no errors. Any ideas? Quote Link to comment Share on other sites More sharing options...
