Marquis Destiny Error Code Hot
Rafuseca
Hi everyone, we have a 2006 marquis destiny that is showing an error code of HOt. We searched all over and can't find an explanation to this code. We checked and the gfci is working. The control pad won't accept any command and the water temp is at 65 so it must be preventing freezing. We also reset the breaker and it doesn't clear anything. The water level is fine and balanced. Any suggestions? Thank you
