Bypass Hose On 2000 Grandee
fibercoug
Hi fibercoug,
Thanks for the clarification! This is designed to help air escape from your circ pump. When you fill your spa back up, there is air in the circ pump that occasionally does not escape. This line helps release this air and if it is plugged you will increase the chances of an air lock.
Thanks,
Steve
---Hot Spring Spas---
