askeptic Posted July 28, 2013 Report Share Posted July 28, 2013 Hello community, I was hoping someone could point me to a website that has a database that contains spa cover dimensions. I own a 2005 Caldera Geneva Utopia spa and my cover went bad. Not thinking, I tossed the bad one out before measuring it first. I loved the way it fit the spa. It was the original Caldera spa cover. I know it was 90 inches x 90 inches, but I never measured the radius or the spa skirt length. If I measure the radius of the shell, it appears to be 6 in. although I am pretty sure I want to go with 5 inches. Just hoping someone with a similar tub can point me in the right direction before ordering. Thanks! Quote Link to comment Share on other sites More sharing options...
askeptic Posted July 29, 2013 Author Report Share Posted July 29, 2013 Sorry for the confusing post. Let me clear my question up. My spa measures 89 in. x 89 in. with a 6 in. radius, and needing at least a 3 in. skirt. Would it be safe to get a 90 in. x 90 in. with a 5 in. radius and a 4 in. skirt, cover? Or should I bump it up to 91 in. x 91 in. ? Thank you! Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted July 30, 2013 Report Share Posted July 30, 2013 If whatever spa cover company you are buying the spa cover from doesn't have the specs on a 2005 Caldera Geneva I would stay far away from them. A legit company will know exactly what you need from the year and model. Quote Link to comment Share on other sites More sharing options...
Hot Spring Ace Posted July 30, 2013 Report Share Posted July 30, 2013 Hello community, I was hoping someone could point me to a website that has a database that contains spa cover dimensions. I own a 2005 Caldera Geneva Utopia spa and my cover went bad. Not thinking, I tossed the bad one out before measuring it first. I loved the way it fit the spa. It was the original Caldera spa cover. I know it was 90 inches x 90 inches, but I never measured the radius or the spa skirt length. If I measure the radius of the shell, it appears to be 6 in. although I am pretty sure I want to go with 5 inches. Just hoping someone with a similar tub can point me in the right direction before ordering. Thanks! You just got 8 years out of the original cover and loved it. See your local Caldera dealer and get another of the same that will fit well and insulate well. There may be cheaper options out there but often they are not the same insulating quality, vinyl quality, vapor barrier quality, fit quality... and will they last that long? Quote Link to comment Share on other sites More sharing options...
