lrodptl Posted July 4, 2013 Report Share Posted July 4, 2013 What are the symptoms of an old or tired pump? Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted July 4, 2013 Report Share Posted July 4, 2013 Wrinkles and long afternoon naps. Pumps work or they don't. They don't exhibit signs telling you they're about to start leaking or stop running. Quote Link to comment Share on other sites More sharing options...
lrodptl Posted July 6, 2013 Author Report Share Posted July 6, 2013 So no symptoms if shaft seal or impeller or bearing is failing. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted July 6, 2013 Report Share Posted July 6, 2013 If the shaft seal has failed, they'd be water dripping out of the pump, where the motor shaft goes into the pump housing. Failing bearings make excessive noise. Quote Link to comment Share on other sites More sharing options...
