My old Hayward Super II has been leaking for a long time and I decided to do something about it. I watched some videos on You Tube and opened up the pump. I replaced the gaskets and shaft seal and applauded myself when it didn’t leak anymore. Until the next morning when it started up again and there was an even bigger leak. I took it apart and put it back together multiple times, never getting rid of the leak. On my attempt yesterday, it worked for a couple of minutes and then the pump clicked off.
I took the pump to a local shop. When they hooked it up to power, it sparked. It turned out that two of the wires to the capacitor were rubbed by the mechanism at the back of the shaft and the protective coating was worn away leaving bare metal. The tech first suggested that I stop working on it and get a variable speed pump (I’m considering it). He said that the capacitors both looked fine and that I could probably tape up the wires (he said he wasn’t allowed to do it) and that the pump should work for a while.
I took the pump home, put electrical tape on the bare sections of the wires, and hooked the pump up and nothing happened. Any thoughts? I am not willing to put much money into this--if I have to, I'll go ahead and buy a variable speed. I know all about the rebate from our electric company and the benefits of the variable speed. It's the upfront cost when I've got other bills, like food, mortgage, college tuitions, etc.
