wakelt Posted May 17, 2013 Report Share Posted May 17, 2013 My inground pool was opened last week. I have a Max E Therm heater and an Intellisense Control pad. I have the control pad set to heat the pool up to 82 degrees. The pool water was at 62F when I turned on the heater. The pool heated to 75F but won't heat any higher. I can hear the ETherm stop heating when we get to 75F (it says 75F on the ETherm LED panel). The Intellisense control pad states that the water is at 75F. Any ideas as to what could be causing this, or the best way to troubleshoot ?? thanks wjk Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted May 17, 2013 Report Share Posted May 17, 2013 I have a Max E Therm heater and an Intellisense Control pad. Do you mean Intellitouch? Is the thermostat on the heater turned all the way up (104)? Quote Link to comment Share on other sites More sharing options...
