Hot Spring Spa Control Panel Works But Temperature Readout Is Blank
My Hot Spring Sovereign Spa from 2002 works Ok holding the proper temp and I can turn the jets on from the control panel but the temperature readout is blank so I can't see in order to change the temperature. Do I need to replace the control panel behind the readout bezel to fix it, or is there an individual part on the control panel I should change?
Is this a new spa for you that you bought usd or is it your long time spa which used to show the temp and now its gone?
