abc123 Posted May 6, 2013 Report Share Posted May 6, 2013 ClassicModel FSerial # F461386Built in the last quarter of 1996Dedicated 20amp to the panel The knob area on top of the hot tub is leaking water. It seems to be coming from under the bezel. I see a blow up of all the parts inside, Would I be able to find out what the most likely part or parts need to be changed? This is the big knob on the same side as the control panel of the hot tub. Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted May 6, 2013 Report Share Posted May 6, 2013 That's not an air control, its a water divirter. Just order the valve kit (70849) and hope the plumbing itself is not cracked. Quote Link to comment Share on other sites More sharing options...
abc123 Posted May 6, 2013 Author Report Share Posted May 6, 2013 Thanks for that clarification! its just a small leak so hopefully all else is OK! Quote Link to comment Share on other sites More sharing options...
