Im Stumped....
Hello all,
I have never posted here and just thought I would give you all a try at helping me figure out whats going on with my hot tub....
We recently bought a house with a hot tub already in it. The hot tub was up and running when we bought it. I drained, cleaned and filled it and it ran perfect for about 2 months. One day I noticed the temp was at 100 and would not reach the 103 setting that I had it at. Thinking it was a flow issue, I changed the filter and it heated right back up and ran perfect for about 2 more weeks. It again dropped temp, but this time to 102 and would continually run at 102 and never turn off (trying to reach the 102 setting) . I bought a new filter and changed it with no luck as it still ran continually.
I did a bit of research and changed both temp probes thinking they were sending a false temp reading. After I drained it, changed the probs, re-filled it it heated up to my 103 setting and turned off.
The next day, the temp is again at 102 and runs continually trying to reach 103.
I decided to pull the filter out and see if it was again a bad filter.... it ran at 102 for 2 hours continually and never reached 103.
Im not sure what else is going on... anyone else have the same issue?
Its a 2004 Colman Maxx Spa, 631 series.
