Guest Harp Posted September 22, 2005 Report Share Posted September 22, 2005 Which is better for the walls of a pool? Thanks for any help!! Quote Link to comment Share on other sites More sharing options...
Guest Tim Posted September 22, 2005 Report Share Posted September 22, 2005 Powder coated Aluminum is better than steel. On average, a steel pool will last you 5 to 10 years. Aluminum pools such as Ester WIlliams are warrientied for 40 years. Steel pools will have a warrenty for 5 years. Quote Link to comment Share on other sites More sharing options...
hottub.pool_boy Posted September 25, 2005 Report Share Posted September 25, 2005 they're all good. stick with buying a pool from the guy who makes you feel the most comfortable. he'll back whatever he/she sells for years. Quote Link to comment Share on other sites More sharing options...
DKN1997 Posted November 3, 2005 Report Share Posted November 3, 2005 Which is better for the walls of a pool? Thanks for any help!! if the hole is prepped properly and your finished patio allows water to drain away from the pool, then steel is just fine. No way steel lasts only 5 years!!! There are plywood wall pools 30+ years old still holding up (barely, though) if you want it to really last forever, go with concrete walls. they don't go anywhere. use a good foam behind the liner because the concrete can "snot" a bit and possibly puncture the liner from behind. Quote Link to comment Share on other sites More sharing options...
Interpool Posted November 3, 2005 Report Share Posted November 3, 2005 if the hole is prepped properly and your finished patio allows water to drain away from the pool, then steel is just fine. No way steel lasts only 5 years!!! There are plywood wall pools 30+ years old still holding up (barely, though) if you want it to really last forever, go with concrete walls. they don't go anywhere. use a good foam behind the liner because the concrete can "snot" a bit and possibly puncture the liner from behind. Concur, provided ground water conditions (when they exist) are taken care of, a steel pool will go on and on! Plus, they are unlimited in shape and inside step bench considerations. Go with a dealer you trust, that is key! Quote Link to comment Share on other sites More sharing options...
