Using A Spa
wilfried
There are many:
Don't drink and dive (that was dive) - alchohol dialates all the same stuff as hot water, so drinking while soaking is not generally recommended. Having said that, I will say that I more of my customers do it than not.
A single degree temperature change makes a huge difference. Try not to run your spa hotter than you need.
I like Dichlor as a sanitizer. Cheap, easy, and works just about every time.
If you don't want Chlorine, use Brilliance brand Bromine. One of the few ways to use bromine which actully isn't mostly chlorine anyway.
If you have enough privacy, forgo the suits. They bring in stuff that your spa is better off without. If you don't have that much privacy, you have two choices:
  • Sell tickets
  • Have just one suit for the spa.
Choose one suit for the spa, and just rinse it in clear water between uses. Also, air drying them makes them last longer, and if you do have to launder it, rinse it before using it in the tub.
