studmaster Posted November 2, 2012 Report Share Posted November 2, 2012 Hello everyone! I searched through the forum and didn't find any recent posts about using Magnesium in a Hot Tub/Spa. The benifits on transdermal magnesium have been studied and proven. Most people are also deficient in magnesium in their bodies. I know I feel so much better after Epsom Salt Baths. My questions are: Does it harm the hot tub? And why do more people not use magnesium in their hot tubs? Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 2, 2012 Report Share Posted November 2, 2012 because at the high concentrations that would be used it would interact with the total alkalinity and also the calcium hardness and could precipitate out as magnesium and calcium scale. Magnesium is one of the components of total water hardness, the other being calcium. magnesium scale is much softer than calcium scale but can still be problematic for pumps, heaters, etc. Then again, you can put whatever you want into your own tub If things mess up you just have to pay for any possible repairs. Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 2, 2012 Report Share Posted November 2, 2012 The solubility product of magnesium carbonate is high at around 1x10^(-5) (some sources say 2.38x10^(-6) for trihydrate; one outlier source said 3.5x10^(-8)) compared to calcium carbonate at around 4.8x10^(-9). This means the magnesium level (in molar units) can be about 2000 times higher than the saturated calcium carbonate level before scaling would occur (or about 7 times if one believes the outlier source). Magnesium hydroxide is the other precipitate that can form, but the solubility product is 1.5x10^(-11) so even at a pH of 8 the magnesium concentration would have to be 15 moles/liter so extraordinarily high (at pH 9 it's 0.15 moles/liter but that's still around 15,000 ppm total hardness). The main issue with magnesium hardness is that, like calcium, it reduces the surfactant properties of soap and precipitates magnesium stearate with solubility 30 mg/L (this along with calcium stearate with solubility 40 mg/L form "soap scum"). This is not normally an issue in pools and spas since soap is not used and is actually to be avoided since foaming is undesireable. In fact, calcium is intentionally added to spas to inhibit foaming (but the quantities of soap are usually small enough to avoid soap scum) and magnesium would have the same foaming inhibition effect. Quote Link to comment Share on other sites More sharing options...
spidey9 Posted November 5, 2012 Report Share Posted November 5, 2012 I have some Spa Side aromatherapy crystals by Cover Valet that are made for hot tubs and spas, and the main ingredients are epsom salts, sea salt, and (of course) fragrance. These come with a little scoop that holds about an ounce, and the instructions call for adding one scoop to the water, which is probably nowhere near the concentration that you are asking about. I can't say that I've noticed feeling any better after using them in the spa, but the fragrance does do a nice job of masking the chlorine smell. Quote Link to comment Share on other sites More sharing options...
studmaster Posted November 5, 2012 Author Report Share Posted November 5, 2012 Thanks for the responses! Waterbear: I'll have to look into the correct concentration, but if my memory serves me the concentration they tell you to put into an Epsom Salt bath is roughly between 400-600grams per 600L, which would be about 10Kg on a 400Gallons hot tub if you went on the lower end with 400grams. That is quite a bit. The baths were for 12 minutes at 50-55 degrees celcius, which I believe is warmer than most tubs. chem geek: wow very techical, so laymens terms......adding magnesium shouldn't be a big issue? I guess it would depend on how much I add right? spidey9: Yes you are right, that amount of magnesium probably wouldn't do much at all...when I think they are talking about putting 10Kg into a 400G hot tub. Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 5, 2012 Report Share Posted November 5, 2012 400 grams in 600 liters is 667 mg/L (ppm) and even less in total hardness units so is not horribly high for magnesium so should not be an issue. A 400 gallon tub is 1514 liters so would need 400*1514/600 = 1009 grams or roughly 1 kilogram. I'm not sure how you got 10 kilograms but you are off by a factor of 10. Quote Link to comment Share on other sites More sharing options...
studmaster Posted November 5, 2012 Author Report Share Posted November 5, 2012 400 grams in 600 liters is 667 mg/L (ppm) so is not horribly high for magnesium so should not be an issue. A 400 gallon tub is 1514 liters so would need 400*1514/600 = 1009 grams or roughly 1 kilogram. I'm not sure how you got 10 kilograms but you are off by a factor of 10. haha :-) I made a typo there...its supposed to be 400grams in 60L, not 600L. So my math is right, but my typing is sloppy! :-) Would the form of magnesium matter? Espsom Salt (Magnesium Sulfate) vs Magnesium Chloride? Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 6, 2012 Report Share Posted November 6, 2012 The form would affect the weight used to get to the same magnesium level and for magnesium sulfate you'd need to know if it was anhydrous or heptahydrate, etc. The sulfates could be a potential problem with plaster pools or possibly grout between tile. Well, 400 grams in 60 liters would result in 6666 mg/L (ppm) magnesium and that's pretty high. Probably still not enough for scaling but it's pretty high. It'd probably be better if some spa user or dealer with experience with such high levels were to respond if there are issues here. Quote Link to comment Share on other sites More sharing options...
studmaster Posted November 6, 2012 Author Report Share Posted November 6, 2012 Using Magnesum Chloride would be about 1/20th the cost of Epsom Salts, and it appears as it's better absorbed transdermally. Sourcing it locally is a bit of a challenge though. Surprisingly, from the google searches I've done, using Magnesum in spas doesn't seem too common. Considering all the health benifits magnesium supplementation has, I thought more spa owners would have tried this. Any spa users or dealers with experience can chime in!! :-) Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 7, 2012 Report Share Posted November 7, 2012 One thing I can think of at the very high thousands of ppm level is that this is similar to having very high salt levels in terms of conductivity and therefore potential metal corrosion. Though normally TDS isn't something of concern, if you intentionally increase it to such very high levels, then that is something to worry about, especially for corrosion. I bet spa manufacturers may even say their warranties are voided if you increase TDS that high. Spas aren't necessarily designed to resist metal corrosion as strongly as some pools. This may be particularly true if the heat exchanger in the spa heater is copper instead of cupro-nickel or titanium. Quote Link to comment Share on other sites More sharing options...
studmaster Posted November 7, 2012 Author Report Share Posted November 7, 2012 Thanks chem geek! I'll have to look into the corrosion potential of the water once it hits that high of level. It's a 10 year old hot tub, so warranty would likely be over....plus the original owners didn't leave any of the paperwork. I don't know if I have a heat exchanger, I just replaced the heater on it a couple weeks ago. Quote Link to comment Share on other sites More sharing options...
Spanky Posted November 7, 2012 Report Share Posted November 7, 2012 Another point of concern would be pump seals. If the tub is 10 yrs old the seals are most likely Buna N. Newer tubs ,specifically those designed for SWCG will have "Viton" seals. Yes the seals are only about $20 but they're a PIA to change Quote Link to comment Share on other sites More sharing options...
studmaster Posted November 8, 2012 Author Report Share Posted November 8, 2012 Any thoughts on Magnesium Chloride's interaction with Bromine? Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 8, 2012 Report Share Posted November 8, 2012 No interaction. Think of it as just being another kind of salt. Quote Link to comment Share on other sites More sharing options...
abc123 Posted December 12, 2013 Report Share Posted December 12, 2013 Is there a hot tub that moves the water by air where the salt wouldn't come in contact with the metal ? Quote Link to comment Share on other sites More sharing options...
chem geek Posted December 13, 2013 Report Share Posted December 13, 2013 Is there a hot tub that moves the water by air where the salt wouldn't come in contact with the metal ? No. The circulation of the water is done by moving the water. There is air added to aeration jets, but they also have water. Quote Link to comment Share on other sites More sharing options...
waterbear Posted December 13, 2013 Report Share Posted December 13, 2013 And the water also has to be heated and heat exchangers are metal. Quote Link to comment Share on other sites More sharing options...
abc123 Posted December 24, 2013 Report Share Posted December 24, 2013 Thanks! I have recently learned the many benefits of magnesium. Just wondered if I could add it to my hot tub. I will not be trying that. Quote Link to comment Share on other sites More sharing options...
RS1987 Posted January 23, 2018 Report Share Posted January 23, 2018 On 11/6/2012 at 7:00 PM, chem geek said: One thing I can think of at the very high thousands of ppm level is that this is similar to having very high salt levels in terms of conductivity and therefore potential metal corrosion. Though normally TDS isn't something of concern, if you intentionally increase it to such very high levels, then that is something to worry about, especially for corrosion. But why wouldn’t CaCl2 also corrode? I thought the point of keeping it high was to prevent metal pipes from leaching into the water - we have very soft water and end up adding a lot of CaCl2 to increase Ca levels to proper hardness level, ~400 ppm. I think I’m confused about adding enough MgCl2 or MgSO4 to get 6666 ppm - why are you saying this high? I too would like to use Mg salts in place of CaCl2 to raise hardness level for Mg salts health benefits- how many moles of which Mg salts are equivalent in hardness to CaCl2 - ie, how is “hardness “ determined/calculated? I have a 300 gal tub - would Ca hardness test strips work the same for Mg? Those are what I use to determine proper Ca levels. Quote Link to comment Share on other sites More sharing options...
RS1987 Posted January 23, 2018 Report Share Posted January 23, 2018 On 11/6/2012 at 11:53 AM, studmaster said: Using Magnesum Chloride would be about 1/20th the cost of Epsom Salts, and it appears as it's better absorbed transdermally. Sourcing it locally is a bit of a challenge though. I’m wondering same things- how much MgSO4 and also MgCl2 is equivalent to CaCl2 for hardness? Would test strips that are used to indicate Ca hardness levels also indicate Mg? One thing about MgCl2 transdermal absorptivity - how would one know if too much Mg was absorbed - I sit in tub for 15 - 25 min nightly. And does MgSO4 also absorb transdermally and to what extent? It is difficult to move most compounds across the skin barrier which is why there are so few transdermal patches in general - most compounds need a specific carrier, like a specific alcohol. How do you know MgCl2 easily passes transdermally as an aqueous solution? Quote Link to comment Share on other sites More sharing options...
al_novak Posted June 12, 2018 Report Share Posted June 12, 2018 If trying to use a chlorine generator with Magnesium will more than likely cause the salt system to read incorrect salt levels and have errors. Mineral salts will also cause issues with chlorine generators and their ability to measure salinity. Plain sodium chloride is what most systems are calibrated for. I use https://poolchemicalcalculator.com/Pool-Salt-PPM-Calculator.html to balance salt ppm. Quote Link to comment Share on other sites More sharing options...
Terrimcall Posted April 28, 2019 Report Share Posted April 28, 2019 I’ve wondered this for years. I learned a lot reading this. Thank you! Still, I wish I could use something besides bromine. I’ve heard that is depleting. Quote Link to comment Share on other sites More sharing options...
onetaste Posted January 20, 2020 Report Share Posted January 20, 2020 I would like to use Magnesium Sulphate to replace Calcium just for the purpose of maintaining correct water hardness (not to get the spa to therapeutic levels of Mg). Is this possible, does anyone have any experience with this? Quote Link to comment Share on other sites More sharing options...
onetaste Posted January 26, 2020 Report Share Posted January 26, 2020 bump I would like to use Magnesium Sulphate to replace Calcium just for the purpose of maintaining correct water hardness (not to get the spa to therapeutic levels of Mg). Is this possible, does anyone have any experience with this? Quote Link to comment Share on other sites More sharing options...
RetroPDX Posted October 11, 2020 Report Share Posted October 11, 2020 There's a difference between magnesium chloride and the form of magnesium in Epsom Salts - but they are both salty that can cause corrosion depending on how much you put into the tub. It sounds like therapeutic quantities are cautioned not just because of corrosion, but possible interaction with bromine and cost prohibitive. I use a non bromine product called Spa Cuzn that lasts 4 months - maybe uses copper? - without any additional sanitizing than a weekly dose of potassium monopersulfate shock. I'm in love with this product and want help figuring out if I should be concerned about using it. I also would like to bump up the therapeutic quality of my spa by adding magnesium chloride flakes. Without the bromine interaction should I still be concerned? Quote Link to comment Share on other sites More sharing options...
