jbaker00 Posted October 21, 2012 Report Share Posted October 21, 2012 I have a Hot Springs Landmark hot tub, bought new in 2002. Not getting power to the heater. Well, first the heater relay board shorted out and blew. I bought a new heater board and installed it today, but the heater is still not working. The no fault heater seems ok, tested it with meter and got about 10 ohms between wires. The circulation pump is running. On the main board the green light is on and the red light is on. Still getting no voltage to the heater though. Could the new board be bad or maybe a relay on main board. Anyone have any ideas on what could be the problem. Thanks. Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted October 22, 2012 Report Share Posted October 22, 2012 Never seen a new heater board not work if it was the only problem. Are you sure it is wired right and the heater breaker is on and not tripped? Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted October 22, 2012 Report Share Posted October 22, 2012 Double check your voltage on the 30 amp line 240v, and double check the wiring diagram. Be sure you're metering between 1 and 3 to get 240v Quote Link to comment Share on other sites More sharing options...
