jwhite216 Posted September 30, 2012 Report Share Posted September 30, 2012 My Marin spa suddenly stopped working. I reset the breaker and still no response. There is power to the board. I thought the board was bad (there were two blown fuses that I replaced and still no response), so I replaced the board per instructions and still no response. There is continuity on the fuses. The control panel is completely blank and pumps do not turn on. Any suggestions? Quote Link to comment Share on other sites More sharing options...
JAMES THE HOT TUB GUY Posted October 1, 2012 Report Share Posted October 1, 2012 Two things you connot check the fuses in the board you need to pop them out then check them too see if they are bad if they are not then check the transformer hope this helps. Quote Link to comment Share on other sites More sharing options...
jwhite216 Posted October 1, 2012 Author Report Share Posted October 1, 2012 That's great...thank you. How do I check the transformer? Quote Link to comment Share on other sites More sharing options...
jwhite216 Posted October 1, 2012 Author Report Share Posted October 1, 2012 I took out all 5 fuses and checked them for continuity and they are all OK. Quote Link to comment Share on other sites More sharing options...
