Katiefrancis Posted September 30, 2012 Report Share Posted September 30, 2012 Hello, I have a Island Spa Grand Bahama 54 jet made by Artesian from 2003. A year ago I had to change out the main control panel with a new one made by Gecko. SInce then My water temperature is not as hot as the top panel says it is. Just to test it I set the temperature on top panel to 102 degrees and left it all night. Next day I tested the water with 3 differant thermometers and they all read betwee 97 and 96 degrees. I have read that I should test the temperature probe. How do I get to it. I dont want to force that little cover thing off it because I don't know if I am suppose to. ALso I read some thermostats need to be calibrated. How do I get to the thermostat? ANd how do I know if this is the type to calibrate. Before this new control panel was put it the termperature was perfect. The new control panel did come with a new temperature probe but we just kept the old one in because we didn't know how to change it and figured that it was good. Thanks, Katie also is there a spell check on this board? I can't find it? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Apollo217 Posted October 1, 2012 Report Share Posted October 1, 2012 The temp sensor or probe should be visible from inside the tub. It looks like a little nub sticking out somewhere in the tub. Not too familiar with artesian so not sure exactly where it's located Quote Link to comment Share on other sites More sharing options...
