notwet Posted August 21, 2012 Report Share Posted August 21, 2012 Anyone know what code ILOC means thanks Quote Link to comment Share on other sites More sharing options...
JAMES THE HOT TUB GUY Posted August 21, 2012 Report Share Posted August 21, 2012 Yes I do you have an old tub 1992 or earlier sundance spa. Probably a 724 control system was the most common in front of that spa you should have 2 sliding doors at the top right and bottom left there are magnets so when you close the doors the magnets tell the control system that the doors are shut if it is not picking up the magnets it will not turn on take my advice cut the wires and wire them together not too each other each magnet has two wires wire the two together turn power on that should fix you right up. Quote Link to comment Share on other sites More sharing options...
