gmaines Posted August 1, 2012 Report Share Posted August 1, 2012 Just bought a 2012 hot springs vanguard. Love it, problem is it has been around 98 degrees out and we have not used it much.. About 2X a week. What can I use to clean the water line without screwing up the water..... Thank you all.... This is my first spa and I love it. My dealer has been outstanding. I have learned so much from you all. Thanks.... Quote Link to comment Share on other sites More sharing options...
gmaines Posted August 1, 2012 Author Report Share Posted August 1, 2012 Sorry, I have the ace system if that makes a difference. Quote Link to comment Share on other sites More sharing options...
gmaines Posted August 6, 2012 Author Report Share Posted August 6, 2012 Anyone? Quote Link to comment Share on other sites More sharing options...
Chas Posted August 10, 2012 Report Share Posted August 10, 2012 Well, the scum line can be from many different things. The best way is to simply wipe it with a clean cloth. You'll note that the line usually form just a little bit above the water, so you can wipe most of it off without dipping the towel into the water. Start with that - if you need to use something to break the oil/grease, you can use something like: Put a small amount on the towel and it should cut the grease, and if you get some into the water it doesn't foam up. HTH Quote Link to comment Share on other sites More sharing options...
Hot Spring Ace Posted August 10, 2012 Report Share Posted August 10, 2012 Use the product Chas mentions, you won't need much. Let about 2 or 3" of water out so you can get to the scum line easily without getting into the water. As far as what it is, it could be many things. Any teenage girls or makeup wearing people going in? Quote Link to comment Share on other sites More sharing options...
gmaines Posted August 10, 2012 Author Report Share Posted August 10, 2012 Yes, my 2 daughters and wife... Will try heat was suggested. Thanks Quote Link to comment Share on other sites More sharing options...
Hot Spring Ace Posted August 10, 2012 Report Share Posted August 10, 2012 Congratulations on having 2 daughters and a wife. Condolences on what the residual shampoo/conditioner in their hair, skin lotions, makeup, eyeliner, etc. will do to your water. Quote Link to comment Share on other sites More sharing options...
gmaines Posted August 10, 2012 Author Report Share Posted August 10, 2012 It's OK, I am making them clean it.... Lol... Quote Link to comment Share on other sites More sharing options...
Chas Posted August 11, 2012 Report Share Posted August 11, 2012 There is a thing called "Chas' Law," which will come into play here. I may have to modify it for the ACE system, but the basic law is this: do a water change at the end of your first 30 days of tub ownership. Just once, but it makes a huge difference. Quote Link to comment Share on other sites More sharing options...
Spanky Posted August 14, 2012 Report Share Posted August 14, 2012 Congratulations on having 2 daughters and a wife. Condolences on what the residual shampoo/conditioner in their hair, skin lotions, makeup, eyeliner, etc. will do to your water. Invest $10.00 in a "Scumbug". I used to think I was wasting my money, untill my Daughter came to visit with 4 friends. I don't know what sort of make-up and lotion those girls had all over them but the next day the center of my normally white scumbug was yellow/brown. Quote Link to comment Share on other sites More sharing options...
farwellbooth Posted January 30, 2014 Report Share Posted January 30, 2014 I don't see the product Chas recommended above. What's the product? Thank you. A regular rag isn't enough and I also tried Leisure Time Citra Brite of which takes a LOT of elbow grease. Not a high bather load but my wife has makeup, we don't shower before etc. however the water is always clean. thks Quote Link to comment Share on other sites More sharing options...
farwellbooth Posted January 31, 2014 Report Share Posted January 31, 2014 What's a good product to remove yellow scum line? I've tried the Leisure Time Citrabrite and it doesn't really work. thank you Quote Link to comment Share on other sites More sharing options...
mws Posted February 10, 2014 Report Share Posted February 10, 2014 I had a rather prominent scum line on my 3000 gallon swim spa. I simply reasoned: I use muriatic acid in the spa to equalize pH, why not a small amount in a bowl to break down the scum? I used gloves and goggles and it came right off with a scotchbrite sponge. Used Muriatic acid and steel wool on some rust on teh acrylic surface as well, also worked great. No fears of leaving a chemical that might suds up in the spa. Quote Link to comment Share on other sites More sharing options...
