Pool Clown Posted July 16, 2012 Report Share Posted July 16, 2012 Are you are a tech? have you been experiencing a rash of temp sensors going bad? How many would you say in the past 6 months? Are you a pool owner?, and had your temp sensor go out on your new automation? I'm going to be talking to a automation rep from Pentair, and would like to let him know the size of the the failures. Thanks, PC Quote Link to comment Share on other sites More sharing options...
Ao1 Posted July 17, 2012 Report Share Posted July 17, 2012 I see the ts5L fail all the time, though it normal is in older pool systems, I haven't seen very many on pools still in pentairs warranty fail. Maybe 4 in the last 3 years and one of those was on an ez touch. The older model intellitouch and cp units seem to need the sensors replaced every couple of years. I would say it is is the weakest link in there controllers. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 17, 2012 Author Report Share Posted July 17, 2012 Thanks for the input, however i should have been more clear. This is regarding the newer style temp sensor(red and black wires) part number 520272 that are associated with the Pentair "touch" series automation. Quote Link to comment Share on other sites More sharing options...
CT Pool Guy Posted July 16, 2016 Report Share Posted July 16, 2016 I have a related question. Recently, my Freeze Circuit is activated and I cannot seem to shut it off. I have a feeling that it may be because of a bad air temperature sensor because on the panel inside there is the display 'air temp sensor error' and I attempts to recalibrate it fail. So does anyone know if the default logic of the Intellitouch system activates the Freeze Circuit if an air temp sensor fails? Thanks a lot Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 18, 2016 Author Report Share Posted July 18, 2016 This thread started back in 1012. Since then, a temp sensor problem had been validated. No calibration will fix this as the problem will cause the temp to continue to "drift". Only a replacement will remedy this. Quote Link to comment Share on other sites More sharing options...
