walleye Posted July 1, 2012 Report Share Posted July 1, 2012 I am thinking I am going to try the technichlor system. I was told that I can use the Taylor 2106 for chlorine simply by dividing the test used for bromine in half? Is this accurate? THX Quote Link to comment Share on other sites More sharing options...
chem geek Posted July 1, 2012 Report Share Posted July 1, 2012 That's roughly correct. You really divide the result by 2.25. Note though that the bromine test does not distinguish between free and total chlorine, but if your combined chlorine (CC) is normally close to zero, then that won't matter. You can get the R-0003 separately to test for CC. Quote Link to comment Share on other sites More sharing options...
waterbear Posted July 1, 2012 Report Share Posted July 1, 2012 you will also need to add the CYA test kit Quote Link to comment Share on other sites More sharing options...
