Salt Chlorine Generator And Pump Timing With Heat Pump
Hi, we just bought a 13 x 25 semi-inground wood pool equiped with a heat pump and a salt chlorine generator. In reading through the Salt system guide, they indicate that the system runs whenver the pump runs, and they recommend this to be anywhere from 6 to 8 hours a day. The heatpump however typically provides its best effenciency if it works all the time, and has its own thermostat to properly control the water temperature. How should a system like this be properly plumbed and configured?
Thanks.
