Mr Putershmit Posted May 28, 2012 Report Share Posted May 28, 2012 Hey Guys, I have a 15 amp 240V Waterco Portapac Heat Pump (air button model). It will work for about 60 seconds and then trips out. I have to push the reset power button and the "power" light comes on again. Turn on the jets and it will run for up to a minute and then cuts out. It doesn't trip the main power on house, just the pump itself. Any ideas? Cheers Quote Link to comment Share on other sites More sharing options...
Mr Putershmit Posted June 13, 2012 Author Report Share Posted June 13, 2012 For anyone who has this problem or owns one of these. It was a case of a small amount of water getting into the electronic control box and slowly corroding the wire thermostat. Replaced that and blocked the leakage and its back to normal. Quote Link to comment Share on other sites More sharing options...
Joycee Posted May 10, 2022 Report Share Posted May 10, 2022 Portapac 15amp spa pump trips out after1hr + been checked out " no problem found" switches on/ off heat on /off but after reset 1hr trips again need very urgent reply this is second new pump both did same Waterco dont want to know Quote Link to comment Share on other sites More sharing options...
