soleskier Posted May 13, 2012 Report Share Posted May 13, 2012 I am chasing an issue with my 2003 Hot Springs Grandee. The hot tub is only heating to 90-94 and will occassionally reach 98. Symptoms: Heat will only increase with Jets on 94 degrees avg temp when thermostat set at 100 Took 3 days to come up to 90 degrees after refill all pumps and Ozone seem to be fine and running with no issue Running without fitlers installed- same result- low heat Bubbles are coming from bottom drain when main pumps off When I lower/raise thermostat I can hear and see heater LED come on and off I have turned off both mains 20 and 30 AMP to reset plus main on fuse box for 30 mins Remediation steps to date: cleaned all filters in proper way Replaced both thermistors first- no change Replaced heater - no change Any ideas are appreciated. Thanks in advance. Sole Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted May 14, 2012 Report Share Posted May 14, 2012 After confirming breaker voltage is solid- replace the heater PCB Quote Link to comment Share on other sites More sharing options...
soleskier Posted May 14, 2012 Author Report Share Posted May 14, 2012 Thanks for the reply. I am sure you are correct. I inspected the heater relay board and the black wire that goes to main board was crusty and black. The wire was all melted on relay board side; i cleaned it up but still no heat beyond 93-4. Are those boards easy to replace? Thanks Sole Quote Link to comment Share on other sites More sharing options...
mitchellpsp Posted May 15, 2012 Report Share Posted May 15, 2012 Is it IQ2020 from Watkins? Yes...easy. Pretty easy to find too. Flip board over to see extent of charring. OR...check out my post on these boards. Quote Link to comment Share on other sites More sharing options...
soleskier Posted May 15, 2012 Author Report Share Posted May 15, 2012 All FIxed! New Heater relay board. 10 minute install. Done! thanks for the help Quote Link to comment Share on other sites More sharing options...
