dsmobla Posted May 9, 2012 Report Share Posted May 9, 2012 Hi, I just tried starting up my pool heater and the code FL0 comes up. According to the manual a good cause is dirty pool water. My pool water is okay so I don't think this is a cause. There is some mention of the pressure switch. I took a look at it and it is a little discoloured. My question is should there be water coming out of the siphon tube when I disconnect it from the pressure switch? There is not. Thanks, Dave Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted May 9, 2012 Report Share Posted May 9, 2012 Water would come out if the pump was on. Air would go in if the pump was off. Scott Quote Link to comment Share on other sites More sharing options...
dsmobla Posted May 9, 2012 Author Report Share Posted May 9, 2012 Hi Scott, The pump was on and there was no sign of water exiting the tube. That would explain the error code. But why is there no water coming out while the pump is running? What should I check? Thanks, Dave Quote Link to comment Share on other sites More sharing options...
Bugman1400 Posted May 9, 2012 Report Share Posted May 9, 2012 Do you have a bypass around the heater? Got a picture of your system? Quote Link to comment Share on other sites More sharing options...
dsmobla Posted May 9, 2012 Author Report Share Posted May 9, 2012 No bypass is installed. I will try to take a picture later. Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted May 10, 2012 Report Share Posted May 10, 2012 Sounds like a corrosion issue in the tube. The water comes from the manifold's return side, IIRC. IT will need either reaming or replacing. Check the pool water for copper too. Scott Quote Link to comment Share on other sites More sharing options...
dsmobla Posted June 10, 2012 Author Report Share Posted June 10, 2012 Hi, I wanted to let everyone know it was the water line. It was blocked at the beginning of the run to the pressure switch. Quote Link to comment Share on other sites More sharing options...
