rebuck39 Posted April 19, 2012 Report Share Posted April 19, 2012 I have recently accquired my new spa and it cycles automatically for filtering and heating. I have read the booklet that came with it and it describes how to change the settings, however I am wondering how often and for how long it should cycle to provide adaquate fitering. The tub is usually only used by one and no more that two people. Also I have read here that some folks use a submersible pump to drain their tubs, any recommendations on a good pump. Thanks very much, and thanks for recommending the Taylor test kit, it has made things much easier. Rebuck Quote Link to comment Share on other sites More sharing options...
Spa_Guru Posted April 21, 2012 Report Share Posted April 21, 2012 Basically run the filter enough to keep the water clear, the amount needed will vary with tub size and use duration. Quote Link to comment Share on other sites More sharing options...
rebuck39 Posted April 23, 2012 Author Report Share Posted April 23, 2012 Thanks for the reply, Spa Guru, it seemed like it was running more often than necessary, but seems to have slowed down some now. I will leave the default settings. Quote Link to comment Share on other sites More sharing options...
