cnet2000 Posted April 7, 2012 Report Share Posted April 7, 2012 I Have a Jandy Aqualink RS, the pool and spa lights turn on without any scheduled programs. This has been happening ever since the pool was built in 2005. No pool guy has been able to figure out the problem. The following actions have proven a failure: HARD REST RESET, AND CLEAR ALL PROGRAMS (THE HARD RESET IS WHEN YOU HOLD DOWN THE RESET BUTTON FOR 10 SECS AND TURN OF BREAKER WHILE STILL HOLDING BUTTON IT, THEN TURN POWER ON WHILE STILL HOLDING RESET BUTTON 10 SECS then lettting go) DISABLED THE SPA SIDE CONTROL TO RULE OUT THAT AS WELL The lights come on every night at around 9PM and off at around 11PM, i usually just turn it off by the remote. Just so you know, there are 0 programs for the pool or spa lights, they just randomly come on without any program. Please help. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted April 8, 2012 Report Share Posted April 8, 2012 Those units have been out for a long time, and for the most part, have been pretty bullet proof. But now, like with everything else, time is taking its toll on these boards, and i'm starting to see things like this (bugs) which are not fixable. I would suggest that you call Jandy, and have one of their techs go through pretty much what you have already done. It may be wise to play dumb, and not tell him that you have done all the re-sets. If you do, and he senses that you are irritated for having to go though all that again, he may not want to help as much as he could, and would rather just move on (to the next customer). My two cents... Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted April 8, 2012 Report Share Posted April 8, 2012 Can you open it and look at the version of code on the controller board? Scott Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted April 8, 2012 Report Share Posted April 8, 2012 Not sure if knowing the firmware version will help as any version update requires a new chip/board, which he is looking at anyway. Jandy does not provide for a firmware flash update on an existing chip. Quote Link to comment Share on other sites More sharing options...
cnet2000 Posted April 8, 2012 Author Report Share Posted April 8, 2012 on the remore is rev. b13 Quote Link to comment Share on other sites More sharing options...
cnet2000 Posted May 19, 2012 Author Report Share Posted May 19, 2012 i figured it out... it was a setting called dusk dawn settings under the settings menu... just had to turn it off.... Quote Link to comment Share on other sites More sharing options...
ToddSpitzer Posted December 29, 2014 Report Share Posted December 29, 2014 I have had phantom pool light and waterfall phantom issues for six months. I read this article since it is the ONLY one on the Internet that addresses or comes close to addressing the issue. I did a hard and soft reset; cleared out my handheld remote memory and reprogrammed it; pull ALL the pins and wires and cleaned each one and reinserted; and open up the remote attenna box and reset the sending and receiving signal. I made it TOO complicated! The four button spa switch inside the spa and partially under the water line is set via the menu/spa switch with four button assignments: spa; spa heat; pool light; waterfall. I reassigned the spa switch settings to take out the pool light and voila! No issue. I simply have an IN THE SPA itself push button control that has water in it and is shorting and sending a signal to the motherboard. I wanted to add this solution to this page since it took me four months to figure out and no one should have to wait that long! Quote Link to comment Share on other sites More sharing options...
