scottymac Posted January 29, 2012 Report Share Posted January 29, 2012 Hi all! I need to replace a check valve on my system. It looked as though my system had a removable valve but upon inspection everything is glued on tight. I've included a picture to show you the setup and check valve. Anyone have any advice on where to cut for the new install. Because of the 90 degree joint, I don't have enough length to use a coupling and glue the new one in. Any help is appreciated! Here is a link to the picture I took of it...http://www.flickr.com/photos/60043719@N05/6785091283/ Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted January 29, 2012 Report Share Posted January 29, 2012 A 2" fitting fits on the outside of the valve port. Just cut the 1.5" fitting flush at the valve port and at the bottom of the existing check valve. Glue a 2" socket 90 (Schedule 40 only) as needed. Note: If this is for a raised spa, lower the water in it first! Scott Quote Link to comment Share on other sites More sharing options...
scottymac Posted January 29, 2012 Author Report Share Posted January 29, 2012 ahhh, makes perfect sense. Thank you very much Scott! Quote Link to comment Share on other sites More sharing options...
