D1 Nautilus Electrical
packfan
I'll preface this by saying I'm not familiar with the D1 Nautilus, but if it's similar to other tubs from the major manufacturers it most likey has a (1) single speed and (1) dual speed jet pump. The 50 amp configuration will allow you to operate both pumps at the same time, but WITHOUT the heater. The 60 amp will allow you run everything simultaneously.
  • 1 month later...
That's right we can run the heater the pumps on high speed , and the 24/7 circ pump all at the same time...
Just out of curiosity, if everything works on the 50 amp configuration, what's the advantage of installing the 60 amp configuration? There's definitely a price difference.
gman B)
