mag357 Posted September 16, 2011 Report Share Posted September 16, 2011 For the last 5 days or so I have noticed large bubbles in the jandy pump filter glass, that looks like it bubbling over in the glass. I have tried bleeding the air using the pressure release valve on top of the filter unit. Now this is not happening every day, but 3 out of 5 days I have noticed the problem. How can I fix this. The pool is only three years old. Thanks Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted September 17, 2011 Report Share Posted September 17, 2011 Try changing the lid gasket. Scott Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted September 19, 2011 Report Share Posted September 19, 2011 What type of pump? Some of those Jandy pumps have a way over-sized pot, and i see that alot. Check the lid oring, as advised previously, and i think you will be OK. Sometimes, as the filter gets dirty-er, the flow decreases, and bubbles like that become harder for the pump to clear to the filter. Quote Link to comment Share on other sites More sharing options...
mag357 Posted September 27, 2011 Author Report Share Posted September 27, 2011 I could confirm that it was pulling air through the lid-cover "O" ring. I did place an order for a new o ring. However, what I did was remove the o ring and cleaned the groove for the ring and re-seat the old o ring and the problem is solved. Five days now and not one bubble. I will keep the new ring just in the event the old one goes bad againg. I want to thank you guys for your helpful replies. Quote Link to comment Share on other sites More sharing options...
AFiremanFirst Posted October 5, 2011 Report Share Posted October 5, 2011 Great! Air leaks can be a big problem. Often times you can turn your pump on and let it prime (best it can) and then shut the pump off. With a good ear next to the pump, and valves before it... the leak will show you it's place. Quote Link to comment Share on other sites More sharing options...
