Bugman1400 Posted September 4, 2011 Report Share Posted September 4, 2011 My 5-way valve is starting to pour water from multiple cracks in the housing. It was patched by the previous homeowner with some type of JB Weld. Currently, it is a 75GPM valve. My question is whether or not to with a 100GPM valve or back to the original 75GPM valve. I have a LX400 heater with 2" piping, the pump is a 1HP pump, the DE filter is 48SQFT. All of the piping to and from the pool is 1.5" pipe. The pool is a vinyl 26K GALs, I have 1 skimmer w/ drain, a main drain on the bottom, a main jet by the stairs, and two smaller jets on the other side of the pool. The existing 1HP pump runs good with no leaks but, I am not above replacing too. I also have a AquaLink RS system that controls the pump, lights, heater, etc. Any suggestions? Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted September 6, 2011 Report Share Posted September 6, 2011 I don't see a big difference in performance so I would go with the less expensive 1.5" part. Scott Quote Link to comment Share on other sites More sharing options...
