mag357 Posted July 9, 2011 Report Share Posted July 9, 2011 In ground pool about 3 years old, with elevated spa. Jandy system, pool is 7x15 irregular shape 14,500 gallons and spa 750 gallons. A few days ago I noticed after pump turning off, a few a couple of hours the water in the tub started going down I first thought it was a leak but then noticed the water in the pool rising. A friend told me to check the check valve I did and noticed the plastic flap dangling in the window with the spring broken. Is this difficult to fix and if not, what are the steps in fixing it? Any help I will greatly appreciate. Quote Link to comment Share on other sites More sharing options...
PoolGuyNJ Posted July 9, 2011 Report Share Posted July 9, 2011 Assuming they used a Jandy check valve, the easiest is to get another. Then remove the 8 screws on each and swap the top halves. Tighten the screw back up and yer dun dun dun! Scott Quote Link to comment Share on other sites More sharing options...
mag357 Posted July 9, 2011 Author Report Share Posted July 9, 2011 Assuming they used a Jandy check valve, the easiest is to get another. Then remove the 8 screws on each and swap the top halves. Tighten the screw back up and yer dun dun dun! Scott Thanks for the quick reply PoolGuy. Yes it's all Jandy, to include the valve. I think I will make a go at it. First time for everything. Thanks again for the reply. Quote Link to comment Share on other sites More sharing options...
