Samdy Posted June 10, 2011 Report Share Posted June 10, 2011 Greetings, I am taking a 1 week vacation. What precautions should I take so as to not come back to a tub full of nasty water? Thanks, Quote Link to comment Share on other sites More sharing options...
Even Further Posted June 10, 2011 Report Share Posted June 10, 2011 Might want to include what sanitizer you use, and existing habits. I had to switch to Bromine because of my schedule. I couldn't leave the the tub for 4-5 days using Dichlor/Bleach. I can leave the tub for 5 days no problem with Bromine & floater. Quote Link to comment Share on other sites More sharing options...
endorfin Posted June 11, 2011 Report Share Posted June 11, 2011 I know this topic has been discussed a lot in the past. But I was wondering, how low do you need to drop the temperature for a pool floater to be effective (assuming chlorine sanitizer and need to leave for a week)? If you drop to 85 degrees, can you use trichlor floater to maintain FC and then just continue with bleach when you can? Quote Link to comment Share on other sites More sharing options...
waterbear Posted June 11, 2011 Report Share Posted June 11, 2011 I know this topic has been discussed a lot in the past. But I was wondering, how low do you need to drop the temperature for a pool floater to be effective (assuming chlorine sanitizer and need to leave for a week)? If you drop to 85 degrees, can you use trichlor floater to maintain FC and then just continue with bleach when you can? I would not recommend it because of the very low pH of trichlor. You run the risk of depleting the TA and having the pH crash very low which can cause damage to heat exchangers and other spa parts. You still are dealing with a very small volume of water. If you have added borates then you should not have any major problems and just need to superchlorinate and make sure there is not CC when you return before using the tub. Even without borates in the water i would just shut the tub off and then shock and rebalance when you return. Algae growth should not be a problem because the tub is covered and algae needs sunlight to grow and since there is no bather load you are not adding any more organics. Superclorinating and testing to make sure that CC is o ppm should get your water ready to soak in again. Quote Link to comment Share on other sites More sharing options...
endorfin Posted June 11, 2011 Report Share Posted June 11, 2011 aha! Thank you Bear. Quote Link to comment Share on other sites More sharing options...
Samdy Posted June 11, 2011 Author Report Share Posted June 11, 2011 Might want to include what sanitizer you use, and existing habits. I had to switch to Bromine because of my schedule. I couldn't leave the the tub for 4-5 days using Dichlor/Bleach. I can leave the tub for 5 days no problem with Bromine & floater. I use Bromine in a floater, and a shock a couple times a week. What other habits would be helpful to answer? I plan on filling the floater with tabs, adding some shock and setting the temp at the lowest possible, mid 80's I think, without shutting it off. Quote Link to comment Share on other sites More sharing options...
waterbear Posted June 12, 2011 Report Share Posted June 12, 2011 aha! Thank you Bear. NOT a bear, a tardigrade! Quote Link to comment Share on other sites More sharing options...
endorfin Posted June 12, 2011 Report Share Posted June 12, 2011 Correction - thank you Quote Link to comment Share on other sites More sharing options...
Samdy Posted June 17, 2011 Author Report Share Posted June 17, 2011 Might want to include what sanitizer you use, and existing habits. I had to switch to Bromine because of my schedule. I couldn't leave the the tub for 4-5 days using Dichlor/Bleach. I can leave the tub for 5 days no problem with Bromine & floater. I use Bromine in a floater, and a shock a couple times a week. What other habits would be helpful to answer? I plan on filling the floater with tabs, adding some shock and setting the temp at the lowest possible, mid 80's I think, without shutting it off. Well, that worked just fine. Quote Link to comment Share on other sites More sharing options...
