hurook Posted June 7, 2011 Report Share Posted June 7, 2011 I have an issue with a Z115/Z315 echo spa. I had it up and running all last year just fine until winter came. Then when I went out to check it one week, the spa had shut down and there was a thin layer of ice on top, about 1/4" or so. The breaker had tripped. I tried restarting to see if I could "save" it rather than unfreezing and draining. The pump motor kicked in for a few seconds and then quit. So I used space heaters to completely thaw and then drain the spa. This spring, I have no power power to the topside control. I did isolate the pump motor to make sure I didn't burn it out and it works. There is power to the board as I was using a multimeter to check a few of the relays. I haven't replaced the fuses yet, but will do so just to rule it out. Just looking for suggestions as to where I should start troubleshooting from someone with more experience. Any help or suggestions is much appreciated! Quote Link to comment Share on other sites More sharing options...
