BillinKingstonSprings Posted May 25, 2011 Report Share Posted May 25, 2011 Lite2 Pool and Spa Heater, Model LJ 400,000 BTU Propane - Is this pool heater reliable and can it heat a 18x36 Inground Pool? Also can it be converted to NG? I found one that is used for $500.00 Quote Link to comment Share on other sites More sharing options...
sharkman009 Posted May 25, 2011 Report Share Posted May 25, 2011 Lite2 Pool and Spa Heater, Model LJ 400,000 BTU Propane - Is this pool heater reliable and can it heat a 18x36 Inground Pool? Also can it be converted to NG? I found one that is used for $500.00 That is a reliable heater it just depends on how well it was maintained. It is able to handle heating a pool that size and a propane conversion kit is available for that. Most kits require you to change the gas valve and orifices/ If your pretty mechanical you may be able to find a conversion kit that you just change the daighram in the valve and the orifices. Id price the parts out before you invest in a used heater. Quote Link to comment Share on other sites More sharing options...
BillinKingstonSprings Posted May 26, 2011 Author Report Share Posted May 26, 2011 Thank you for the input. Quote Link to comment Share on other sites More sharing options...
