Errol 0 Posted May 23, 2011 Report Share Posted May 23, 2011 Every thing was working great with the Polaris. I changed to pool temperature to match the current reading, and now the auto-cycle and sanitizing lights will not come on, and the display is blank. I tried pressing the restart and test buttons simultaneously to reset, and nothing changed. The sanitizing light comes on if I press the 24 hour boost. I completely disconnected the electrical supply to the system and left it for 30 minutes, then hooked it back up. Still no reading on the display, and auto-cycle and sanitizing lights are still off. I tried resetting the water temp, and run times. Display works when setting temp, and run time, but then it goes blank, and auto cycle and sanitizing lights are off. Any ideas would be appreciated. Errol Quote Link to post Share on other sites
mrwickett1@gmail.com 0 Posted May 27, 2020 Report Share Posted May 27, 2020 Did you find the problem? Quote Link to post Share on other sites
