rhisurfer Posted March 14, 2011 Report Share Posted March 14, 2011 i have a 4 person spa made by 'Strong Spas'. The last owner told me that i could plug the spa into an outlet made for 120 voltage. I've had it working fine for about 2 months, and it stopped working the other day. i read about this spa, and the owner's manual recommend 240 voltage. The spa will not turn on. I have tried flipping the circuit breaker switch a few times, and it won't come on. i also tried resetting the spa, but this didn't work either. When this first happened, i flipped the breaker, and it came back on, but turned later on that night....any advice on what to do at this point? does it sound like i just need to increase the voltage on my outlet? or is the problem worse? any help would be greatly appreciated.... Quote Link to comment Share on other sites More sharing options...
AFiremanFirst Posted March 19, 2011 Report Share Posted March 19, 2011 Increase your voltage? NO!!! How would you do that? 220/220 is more effecient than 110/120, that is probably the biggest reason it is reccommended. If I were in your shoes. I'd unplug my hot tub until I could get an electrician to verify that I don't have a new electrical problem in my walls! Something that could cause a fire! You may have aluminum wiring, or wiring that was too small to carry the current, and over time, a problem has developed! It is my guess that your problem is with your hot tub, but I've seen enough house fires to know that I couldn't sleep at night, not knowing for sure! Quote Link to comment Share on other sites More sharing options...
