mwinslow Posted February 24, 2011 Report Share Posted February 24, 2011 I have a 2003 Down East Providence Spa. The hot tub works great but if you try to put it in a mode to cycle, it will cycle correctly for 24 hours in sleep mode, but after that it will constantly cylce. In standard, or economy mode it will constantly stay on and cyle. Does my pump, circulation pump, or filtration need to be replaced? Any recommendations or ideas? thanks, Mike Quote Link to comment Share on other sites More sharing options...
Kreg Posted February 24, 2011 Report Share Posted February 24, 2011 There are filtration modes that you can customize. Perhaps you have seen an F2, F4, F6, or FC code? My guess is that you have the spa set to FC mode, to filter continuously. Refer to your owners manual to change this back to F2. If you dont have an owners manual, you can pull one off Master Spas website. Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted February 24, 2011 Report Share Posted February 24, 2011 If it has a 24 hour circ pump, that pump will cycle 24 hours a day, even in ecn(it just wont turn the heat on in ecn except during a filter cycle) Quote Link to comment Share on other sites More sharing options...
THE SPA GUY Posted March 2, 2011 Report Share Posted March 2, 2011 I would check to see if you have it set to FC mode like KREG mentioned, I do not belive hat spa came with a low amp 24/7 circ pump,,,sometimes the easiest way to reset it to reset your breaker..... Quote Link to comment Share on other sites More sharing options...
